CSS 11500 Issue
Jun 15th, 2009
I choose the log off option on the Web Server, and I get an error page :-cannot be displayed. Issue only when I use the CSF.
This was working fine before but not sure sudenly the problem started.
Device :CSS 11500
OS: CSF
Any help would be appricatiated.
Sum
Gilles Dufour Mon, 06/15/2009 - 03:27
  • Cisco Employee,
Sum
what version ?? 7.xx(xxx) or 8.xx(xxx) ?
You should capture a sniffer trace on frontend and backend.
Get a trace with the CSS and without and compare the 2 to see where is the difference and which device is at fault.
If you can't see a difference or need assistance understanding the trace, send it to us.
Gilles.
sumaiyausa Mon, 06/15/2009 - 04:39
Hi giles,
I am running 8.20 code and the issue is we use bank application and login will be successful and when the transaction is over when i do logout it doesnt give me the msg saying logout is successful were as it logout and prompt me the login page again.
I loked at the los and found that the referer is null when connected through the vip. HTTP request will have the value of null which is causing this issue.
Kindly let me know what do you think about this.
My config is very simple:
ip redundant-vip 172.16.23.3
service bank
ip address 192.1.1.12
protocol tcp
port 443
active
owner data
content me
protocol tcp
vip address 172.16.23.3
port 443
add service bank
application ssl
advanced-balance ssl
sticky-inact-timeout 50
active
Thanks in advance.
REgards
Sum
Gilles Dufour Mon, 06/15/2009 - 05:07
  • Cisco Employee,
We need the complete version 8.20(????)
And a sniffer trace will be usefull to see what is happening.
Gilles.
sumaiyausa Mon, 06/15/2009 - 05:12
Hi Giles,
sg0820201.
No sniffer traces available as of now. What I am now looking is referer being stripped out http header. Can you tell me how to set to remove or block the http referer info?
Thanks in advance.
Sum.
Gilles Dufour Mon, 06/15/2009 - 05:16
  • Cisco Employee,
Sum,
The CSS NEVER removes the content of HTTP traffic.
We don't even look into the http content.
Gilles.
sumaiyausa Mon, 06/15/2009 - 07:59
Hi Giles,
I looked at the traces but there is nothing much present as the connection works and everything is working fine as it should be but only the problem when i click the logout button of the banking site I get page cannot be displayed this is strange.
Sum
