Changing IP addresses ( eth0 and eth1) of Meeting Place Express
Overall Rating: 5 (1 ratings)
Ginger Dillon Mon, 06/15/2009 - 07:26
  • Blue, 1500 points or more
Hi -
You can use the CLI net command to change the IP addresses of eth0 and eth1:
net - Lists the current network configuration settings and allows you to change them after the system has been installed. Most changes take affect after restarting the system.
Use the net command to set the following:
•Port configuration parameters, including the primary IP address, subnet mask, secondary IP address, default gateway, MTU, and link parameters (auto-negotiation, speed, duplex).
•Hostnames
•Domain name
•DNS servers
•NTP servers
•Static routes
Syntax: net
Here is the maintenance and reconfiguration guide link - http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace_express/2_0/english/administration/guide/cmg.html
Ginger
