Rmon mode after bootup on cisco 4510
Jun 15th, 2009
After a power down we booted up our core switched 4507 and 4510 and both went into rmon mode. Both supervisors had amber leds I had to attach a console cable to each supervsior and boot from command line and it reloaded with correct config. Any help with this would be appreciated
iyde Mon, 06/15/2009 - 04:14
  • Silver, 250 points or more
How is the setting of the config-register for the switches? See the last line of 'show version' after the switches have been fully booted.
The config-register should be something like 0x2102 or 0x2 or 0xF
iyde Mon, 06/15/2009 - 11:44
Did you have a "boot system xxx" statement in your config before you reloaded? I just found this note in the documentation:
If you set bootfield to a value between 0-0-1-0 (binary) and 1-1-1-1 (binary), you must specify a value in the boot system command, else the switch cannot boot up and will remain in ROMMON.
So with your 0x2102 you must have a 'boot system' statement in the config.
