QOS deployment on 6513
Jun 15th, 2009
Hi All,
I have 6513 switch. i have create a template for QOS to be deployed on switch but i m not able to deploy service policy on interface, i m getting error when doing output policy that MQC not supported on this interface , when i do the same with input interface then getting error that NBAR matching protocols are not supported. actually i have create the simple template with allocating bandwidth percent to each class according to its prirority. plz tell me how can i deploy the service policy. and if possible plz suggest any better template for 6513 switch
Joseph W. Doherty Mon, 06/15/2009 - 04:49
See posting "LAN, Switching and Routing: QOS deployment on 6513"
Rui Carlos Antunes Mon, 07/20/2009 - 04:57
Layer-3 QoS is not supported on all Catalyst 6500 line cards.
Typically, Layer-3 QoS is fully supported only on the following linecards:
- OSM cards, such as OSM-2+4GE-WAN+ (EOS)
- FlexWAN modules
- SPA's on SIP's
Can you post the "show module", to see what type of linecards you have?
olsonc0510 Mon, 07/20/2009 - 07:02
I have the spame problem. Basically, I want to throttle bandwidth on a lan port connected to a test server which is running loadrunner. I need the test server to simulate a 6 MB, 10 MB or T1 type of connection. I can't use the bandwidth command (not supported) and both Service-policy "output" or "input" give me an error. Do I not have the right hardware?
access-list 150 permit tcp any any eq 443
Class-map match-any 10MB
Match access-group 150
Policy-map 10MB
Class 10MB
Priority percent 10
Class class-default
set dscp default
Fair-queue
random-detect
interface g1/46
Service-policy output 10MB
interface g1/40
MQC "tagging" features like setting DSCP I believe are input only 6500 virtual interfaces and priority queueing is for
outbound on an interface only.
Mod Ports Card Type Model Serial No.
1 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
2 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
3 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B
6 2 Supervisor Engine 720 (Hot) WS-SUP720-3B
Mod MAC addresses Hw Fw Sw Status
1 0016.4606.0998 to 0016.4606.09c7 10.2 7.2(1) 8.7(0.22)H2A Ok
2 001a.2f57.ea10 to 001a.2f57.ea3f 11.1 7.2(1) 8.7(0.22)H2A Ok
3 0016.4642.4ca4 to 0016.4642.4cd3 10.2 7.2(1) 8.7(0.22)H2A Ok
5 0014.a97e.4d6c to 0014.a97e.4d6f 4.4 8.1(3) 12.2(33)SXH2 Ok
6 0013.c42f.0d9c to 0013.c42f.0d9f 4.4 8.1(3) 12.2(33)SXH2 Ok
Mod Sub-Module Model Hw Status
5 Policy Feature Card 3 WS-F6K-PFC3B 2.1 Ok
5 MSFC3 Daughterboard WS-SUP720 2.3 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B 2.1 Ok
6 MSFC3 Daughterboard WS-SUP720 2.3 Ok
tarnhundal Tue, 07/21/2009 - 01:35
#sh module
1 6 Firewall Module WS-SVC-FWM-1 SAD10490BFF
2 6 Firewall Module WS-SVC-FWM-1 SAD105007UA
3 8 Intrusion Detection System WS-SVC-IDSM-2 SAD104906PT
4 8 Intrusion Detection System WS-SVC-IDSM-2 SAD104906R8
5 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1051BPM9
7 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL10499RSV
8 2 Supervisor Engine 720 (Hot) WS-SUP720-3B SAL10489H8B
9 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL10425KGU
10 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL10414KM6
11 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL10489AQD
12 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL10478XFU
13 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL103828HM
1 001a.6c03.7b3a to 001a.6c03.7b41 4.0 7.2(1) 3.1(3) Ok
2 0019.e78f.1c7c to 0019.e78f.1c83 4.1 7.2(1) 3.1(3) Ok
3 0019.e78f.06a4 to 0019.e78f.06ab 6.2 7.2(1) 6.1(1)E3 Ok
4 0019.e78f.06ac to 0019.e78f.06b3 6.2 7.2(1) 6.1(1)E3 Ok
5 001a.6d9d.9960 to 001a.6d9d.998f 11.1 7.2(1) 8.5(0.46)RFW Ok
7 0016.c85e.3f14 to 0016.c85e.3f17 5.2 8.4(2) 12.2(18)SXF7 Ok
8 0016.c85e.3d68 to 0016.c85e.3d6b 5.2 8.4(2) 12.2(18)SXF7 Ok
9 0018.b9d0.bb6c to 0018.b9d0.bb9b 1.8 12.2(14r)S5 12.2(18)SXF7 Ok
10 0018.b9d0.907c to 0018.b9d0.90ab 1.8 12.2(14r)S5 12.2(18)SXF7 PwrDown
11 0018.b9d2.ca68 to 0018.b9d2.ca97 2.5 12.2(14r)S5 12.2(18)SXF7 Ok
12 001a.2f08.6a20 to 001a.2f08.6a4f 2.5 12.2(14r)S5 12.2(18)SXF7 Ok
13 0019.06da.bd4c to 0019.06da.bd4f 2.5 12.2(14r)S5 12.2(18)SXF7 Ok
Mod Sub-Module Model Serial Hw Status
3 IDS 2 accelerator board WS-SVC-IDSUPG ADBG6460030 2.5 Ok
4 IDS 2 accelerator board WS-SVC-IDSUPG ADBG6460032 2.5 Ok
7 Policy Feature Card 3 WS-F6K-PFC3B SAL10499Q8P 2.3 Ok
7 MSFC3 Daughterboard WS-SUP720 SAL10499N5C 2.5 Ok
8 Policy Feature Card 3 WS-F6K-PFC3B SAL10489KE0 2.3 Ok
8 MSFC3 Daughterboard WS-SUP720 SAL10489KXQ 2.5 Ok
9 Distributed Forwarding Card WS-F6700-DFC3B SAL10489L3Y 4.4 Ok
10 Distributed Forwarding Card WS-F6700-DFC3B SAL1050AQ9D 4.4 PwrDown
11 Distributed Forwarding Card WS-F6700-DFC3B SAL10489CN9 4.4 Ok
12 Distributed Forwarding Card WS-F6700-DFC3B SAL10489L3G 4.4 Ok
13 Distributed Forwarding Card WS-F6700-DFC3B SAL10489L6S 4.4 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
7 Pass
8 Pass
9 Pass
10 Not Applicable
11 Pass
12 Pass
13 Pass
Rui Carlos Antunes Thu, 08/20/2009 - 06:50
The WS-X6548-GE-TX and WS-X6748-SFP cards do not support MQC (Modular QoS CLI).
Only a few cards on the Catalyst 6500 support that (usually referred as WAN cards).
tarnhundal Thu, 08/20/2009 - 07:48
thanx for reply , now what should i do now to apply MQC ?
regards,
Tarn
Rui Carlos Antunes Thu, 08/20/2009 - 08:41
The Catalyst 6500 supports a subset of the MQC.
You need to take a look at the Configuration Guide for your Catalyst 6500's IOS version.
Example: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1465326
You will have to configure LAN QoS commands for those QoS mechanisms that are not supported via MQC.
Example of LAN QoS commands:
-- Global --
mls qos
mls qos map cos-dscp 0 8 16 24 32 46 48 54
-- Interface --
mls qos trust cos
wrr-queue cos-map 1 1 1
wrr-queue bandwidth 30 70
