ANM 2.x supported OS
Jun 15th, 2009
  • Bronze, 100 points or more
I know that Cisco states, that the only supported OS for running ANM 2.x is RHEL 5, but unfortunately my organisation does not support RHEL, only SuSE. We're currently running the following release:
SUSE Linux Enterprise Server 10 SP1 (x86_64) - Kernel 2.6.16.46-0.12
I would of course prefer to install ANM on the supported OS, but if this is not an option, does anyone have any experience running ANM on kernels other than RHEL?
/Ulrich
ldardon Fri, 06/19/2009 - 05:37
It can be possible to install ANM on SUSE Linux Enterprise. After installation if you got any error like lib file missing then install that particular lib file package.
