core files in /apps/CSCOpx/objects/dmgt directory
Jun 15th, 2009
I have serveral files in the /apps/CSCOpx/objects/dmgt directory on a solaris 10 server the are each 3.9 gig each
they are in the attached file- Can I delete them as the server is running out of disk space.
Joe Clarke Mon, 06/15/2009 - 08:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you can delete them. However, this points to dmgtd crashing which could be problematic. If you're experiencing problems with being able to get daemon status, run jobs, etc. then you should open a TAC service request so more analysis can be done. In that case, keep one core file around.
a.oboyle Tue, 06/16/2009 - 03:59
Thank You, I will keep the 3 most recent and open a TAC Case.
