Best practice for hunt groups in cucm 6.1
Jun 15th, 2009
When we migrated from CCM 3.3 to 6.1 we discovered that our hunt groups had to be set up differently to get them to work.
We currently have a dummy phone set up which then forwards all calls to the pilot number which then distributes the calls through the huntgroup.
I'm sure this isn't the most effective way of doing things, so what's the best way to set these up?
Jaime Valencia Mon, 06/15/2009 - 07:29
  • Cisco Employee,
  • Hall of Fame,
    2011
There is really no best practice, i usually configure things as simple as possible. Meaning if the calls come into a DID, configure the hunt pilot with that DID.
java
if this helps, please rate
Rob Huffman Mon, 06/15/2009 - 08:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Lee,
If you don't want to use a "Dummy" phone, look at using a CTI-RP (Route Point) to Call Forward All to the Hunt Pilot DN :) This is an extremely common configuration.
Hope this helps!
Rob
