ACE High Availability Config.
Answered Question
Jun 15th, 2009
Below is my ACE HA config. I have two ACEs and two virtual contexts. I want the context VC_PROD to be active on ACE 1 and standby on ACE 2. I want the context VC_Test to be active on ACE 2 and standby on ACE 1. Also, VLAN 100 is shared between all contexts. Please let me know if I am on the right track. Your feedback is greatly appreciated.
ACE HA Config.
This configuration is on ACE 1. I will repeat the same procedure on ACE 2 swapping the ip addresses.
Context - Admin
interface vlan 100
description Management VLAN
ip address 10.1.1.24 255.255.252.0
peer ip address 10.1.1.28 255.255.252.0
service-policy input Admin_web_MGMT_ALLOW_POLICY
service-policy input SNMP-ACCESS-POLICY
no shutdown
ft interface vlan 110
ip address 192.168.1.4 255.255.255.0
peer ip address 192.168.1.5 255.255.255.0
no shut
ft peer 1
heartbeat interval 300
heartbeat count 10
ft-interface vlan 110
ft group 1
peer 1
priority 100
peer priority 90
associate-context Admin
inservice
ft group 2
peer 1
priority 100
peer priority 90
associate-context VC­_PROD
inservice
ft group 3
peer 1
priority 90
peer priority 100
associate-context VC­_TEST
inservice
Context - VC_PROD
interface vlan 100
ip address 10.1.1.25 255.255.252.0
peer ip address 10.1.1.29 255.255.252.0
access-group input ALL
service-policy input MGMT_ALLOW_POLICY
service-policy input PM_multi_match
no shutdown
interface vlan 111
description VC_Production Server Side
ip address 10.1.111.1 255.255.255.128
peer ip address 10.1.111.2 255.255.255.128
no shutdown
Context - VC_TEST
interface vlan 100
ip address 10.1.1.26 255.255.252.0
peer ip address 10.1.1.30 255.255.252.0
no shutdown
interface vlan 112
description VC_Test Server Side
ip address 10.1.111.129 255.255.255.128
peer ip address 10.1.111.130 255.255.255.128
no shutdown
Correct Answer by dario.didio about 7 years 10 months ago
Taking a look at the commands of FT, we see this:
! creating the FT interface and bind it to a VLAN
! Give the VLAN interface an IP Address to communicate with the other FT ACE
! give the other FT ACE (peer) an ip address to let them communicate between eachother
! enable the interface
no shut
! create the peer ACE parameters
ft peer 1
! heartbeat interval is 300 msec
! heartbeat count is 10 (10 consecutive heartbeats need to be missed before peer declares the other peer down
heartbeat count 10
! bind the created FT interface to the peer
! create a FT group per context
ft group 1
! bind the peer to the FT group
peer 1
! give the ACE a priority
priority 100
! give the peer a priority
peer priority 90
! bind a context to the FT group
! enable the FT group
inservice
in the FT group commands, you specify the context that is linked to that group. That way the ACE knows which context has what priority.
Hope this clears things up!
Please rate if this answered your question or was helpful for you.
Cheers,
Dario
Overall Rating: 5 (1 ratings)
dario.didio Tue, 06/16/2009 - 00:06
  • Silver, 250 points or more
This looks fine!
I suppose you've created your contexts and associated your VLANs to them in your Admin context?
context VC­_PROD
allocate-interface vlan 100
allocate-interface vlan 111
context VC_TEST
allocate-interface vlan 112
HTH.
Kr,
Dario
allen.malanda_2 Tue, 06/16/2009 - 05:28
Thank you very much for your time, I have the contexts created and associated to the VLANs.
With the statement below,
ft group 1
peer 1
priority 100
peer priority 90
inservice
Priority 100 is for ACE 1 and peer priority 90 is for ACE 2. Is that correct? How does the context on ACE 1 or ACE 2 knows that it is priority 100 or 90?
Correct Answer
dario.didio Tue, 06/16/2009 - 13:18
no shut
ft peer 1
heartbeat count 10
ft group 1
peer 1
priority 100
peer priority 90
inservice
Cheers,
Dario
