configure Policy Based Routing - CISCO Router 2800 - ASA 5510
Jun 15th, 2009
Hi All,
Our network is configured as follows:
Cisco Router 2800:
External Interface:
- Two ADSL WAN modules (for internet connectivity)
- A CISCO Switch 2950 on the outside interface which is connected to WIFI APs .
Internal Interface:
- CISCO ASA 5510 which is in turn connected to a CISCO Switch 3560 POE
See attached diagram.
We have created two VLANS within the Switch and distributed our clients accordingly.
We do not have a dedicated IP assigned by our ISP but instead use a Dynamic IP service No-IP.com.
We run the following that require access from external to the network: Exchange email, OWA, SharePoint and VLAN
We have been trying to distribute the traffic to optimise bandwidth utilisation by segregating networks users.
Thank you
thotsaphon Mon, 06/15/2009 - 07:22
Subash,
You may try to do load-balancing for outbound direction.
Please check out these links.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
In case you really want to do PBR. You can separate source of traffic(f.e. 1 vlan each link/ISP) to do PBR on the router. However the links I provided will save you from NAT problems.
HTH,
Toshi
subashmbi Mon, 06/15/2009 - 21:06
Hi Toshi,
I have 2 ATM interface , binds into the dialer0 and 1 for SDSL purpose.
can i use the multilink in the SDSL scenarios.2 dialer into 1 group.
Please find my config.
thotsaphon Tue, 06/16/2009 - 10:35
Subash,
Sorry for replying you too late. In case you want to do MLPPP. You have to make sure that 2 ATM interfaces coming from the same ISP/the same router(Properly be). Because you have to configure this requirement on both sides.
HTH,
Toshi
