MARS 4.x -> 6.x - unable to partition flash disk
Jun 15th, 2009
I'm running a MARS20, 4.3.6 and am trying to upgrade to 6.0.1 by using the recovery DVD (per documentation).
I insert the 6.0.1 recovery DVD I downloaded from Cisco, the MARS device boots from it and I choose 'MARS Operating System Recovery'. The wizard loads a few drivers and reports "unable to partition the flash disk (hda)". At that point, I'm asked to reboot by the wizard, and that's all I can do.
Has anyone ever seen this flash disk error before when doing an upgrade? Is my best bet to open a TAC incident?
Overall Rating: 3 (1 ratings)
gregbeifuss Mon, 06/15/2009 - 08:04
I should add that this is the output of 'diskusage':
Filesystem Size Used Avail Use% Mounted on
/dev/hda3 9.8G 674M 8.6G 8% /
/dev/hda1 129M 14M 108M 12% /boot
/dev/hda5 9.8G 1.2G 8.2G 13% /opt
none 1005M 0 1005M 0% /dev/shm
/dev/hda6 7.9G 3.4G 4.1G 46% /u01
/dev/hda7 3.9G 2.1G 1.7G 55% /u03
/dev/hda8 74G 16G 57G 22% /u02
gregbeifuss Mon, 06/15/2009 - 08:31
Closed -
I realised that I needed to choose 'Distributed MARS - Local Controller' from the DVD boot menu.
