Set clock time zone
Jun 15th, 2009
Is there a way to set the time zone on routers/switches? We're in the Eastern time zone, but some of my switches show UTC (Greenwich Mean Time/Zulu time). I'd like all of them to show the local time, just to make it easier to read.
Overall Rating: 5 (1 ratings)
thotsaphon Mon, 06/15/2009 - 07:33
  • Gold, 750 points or more
Patrick,
You can.
Router(config)# clock timezone <(-23) - (23) ;Hours offset from UTC>
F.e Router(config)# clock timezone CST -6
HTH,
Toshi
Edison Ortiz Mon, 06/15/2009 - 07:43
  • Hall of Fame,
    Founding Member
Toshi has provided the syntax the modify the timezone in the router (btw, Eastern time zone in the US is EST -5).
If you want to see this time being stamped on the log, you need the 'service timestamps' command which can be applied to log messages as well as debug messages
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_r1.html#wp1030116
HTH,
__
Edison.
