Voip config on 2811 series router
Jun 15th, 2009
Does anyone know what the config on the 2811 would look like if VOIP is installed. Just looking for a baseliine configuration to start with.
paolo bevilacqua Mon, 06/15/2009 - 10:10
  • Hall of Fame,
    Founding Member
That all depends on what you want to do and which interface, so you should be more specific.
Generally speaking, if you write something in the search box above, you can then select configration examples.
