2811 or 2821
Answered Question
Jun 15th, 2009
I am upgrading a 5 user remote site from stand alone DSL to T1 P-to_P to regional HQ. I am deciding between a 2811 w/a Switch or a 2821 with a T1 module and Ethernet modules. I'd like to know which way to go, esp. cost wise and parts# needed. Thnx a mil.
Correct Answer by Joseph W. Doherty about 8 years 1 week ago
If you're forced to chose between the 2811 vs. 2821, not a huge difference in performance. The 2821 offers about 41% more forwarding performance, but in absolute terms it's 170 Kpps vs 120 Kpps (64 byte packets). I.e., either could be inadequate for even a single 100 Mbps, although fine for a couple or several T1s.
The 2821 does come with gig Ethernet interface, again not very useful with its low forwarding performance, but it also supports a NME-X module.
If money isn't an object, go with the 2821 to have a bit more capacity. If money is tight, go with the 2811 unless you know for sure you need the 2821.
Correct Answer by paolo bevilacqua about 8 years 1 week ago
You can get a 1861, does voip/CME/SRTS and all the stuff plus it has 8 nice PoE ports.
Sometime you may want to be the one that shows others how to spend money wisely.
Overall Rating: 4.5 (4 ratings)
paolo bevilacqua Mon, 06/15/2009 - 10:49
  • Hall of Fame,
    Founding Member
Honest with you, a 1841 is enough for T1.
mrcooper1 Mon, 06/15/2009 - 11:04
agreed, but these sites are being set up with the hope of going to VoIP in the near future without necessarily having to replace the entire hardware. I figured I can get the proper IOS in and wait for whenever VoIP rolls around. Also, the enterprise is standardised on 2811/2821 and above depending on size.
Correct Answer
paolo bevilacqua Mon, 06/15/2009 - 11:08
  • Hall of Fame,
    Founding Member
mrcooper1 Mon, 06/15/2009 - 12:40
Paolo. I think that will do it. For the goal, a 2811 is a bit much. thnx all.
paolo bevilacqua Mon, 06/15/2009 - 13:22
  • Hall of Fame,
    Founding Member
You are welcome. Please remember to rate useful posts with the scrollbox below.
Correct Answer
Joseph W. Doherty Mon, 06/15/2009 - 12:47
