06-15-2009 11:23 AM - edited 02-21-2020 04:15 PM
Does anyone know if Cisco 3750G switch supports IPSEC and SSH2?
Solved! Go to Solution.
06-15-2009 01:01 PM
06-15-2009 11:36 AM
Mohsen
SSH v2 yes - from the 3750 Q&A
Q. Does the Cisco Catalyst 3750 Series support SSH v2?
A. Yes.
Full link -
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_qas09186a00801b0971.html
IPSEC - no. No catalyst switches with the exception of the 6500 support IPSSEC, for that you need a router.
Jon
06-15-2009 12:46 PM
Thanks Jon!
So, I need to either use a 6500 switch or look into a router with IPSEC capabilities, right?
Mohsen
06-15-2009 12:50 PM
Mohsen
Yes although you could also look at a PIX/ASA device as these support IPSEC as well.
Be aware that with a 6500 you still need an additional card so it is a very expensive solution if all you want is IPSEC :-).
Jon
06-15-2009 12:56 PM
Jon,
Thanks for the quick response! Yes, all I need is IPSEC. Since IPSEC is required for my gateways, I think I'd stay with the 3750G and get a router with IPSEC capability.
Thanks again!
Mohsen
06-15-2009 01:01 PM
Mohsen
Yep, that's what i would do as well.
Glad to have helped.
Jon
