Warning message
VPN clients using MS DHCP servers and VPN 3000
Jun 15th, 2009
I have a number of vpn groups using dhcp pools from the base group on a vpnc 3030 with 4.7. I want to add a new group which uses an external dhcp server. I have enabled the DHCP option in Configuration | System | Address Management | Assignment" but my other groups stop assigning addresses from the base group's pool.
Any one got some good tips or docs for this setup, thanks
John Blakley Mon, 06/22/2009 - 13:17
  • Purple, 4500 points or more
I don't have a concentrator, but I believe you can add the dhcp server option under their particular group policy.
HTH,
John
