Extension Mobility on CME
Jun 15th, 2009
  • Cisco Employee,
Hi all,
I'm configuring EM on CME. I followed the instruction on this page:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html
But the phone's service menu doesn't show any services. I wonder if I missed anything? Here's my related config:
voice logout-profile 1
pin 1234
user kurt password 12345
number 1001,1002,1003,1004 type normal
voice user-profile 1
pin 1234
user kurtem password 12345
number 1002 type normal
ip http server
!telephony-service
em keep-history
em logout 0:0 0:0 0:0
url authentication http://10.1.1.1/CCMCIP/authenticate.asp
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone  1
device-security-mode none
mac-address 0019.E84F.D8D4
logout-profile 1
Thanks!
Marcos Hernandez Mon, 06/15/2009 - 16:10
  • Blue, 1500 points or more
What CME version are you using?  Starting in CME 4.2 and later (due to extension mobility), the service URL was changed so that CME handles the URL via this static entry: "http://CMEIP:80/CMEserverForPhone/serviceurl". Bets you can do here is upgrade your IOS to support CME 7.0 or 7.1.
Marcos
kurmai Tue, 06/16/2009 - 11:16
  • Cisco Employee,
Thanks for the reply Marco. I'm running CME 7.0. I suppose that in CME, as soon as you put in the "url" command, it'll create an entry in every phone's services screen?
Marcos Hernandez Tue, 06/16/2009 - 11:20
No, this will be done automatically and added to the default configuration files. Do a "show telephony-service tftp-bindings", locate the default XML file for your phone and "more" it. You will see the contents there.
Marcos
