UC520, hangs on loading voice data
Jun 15th, 2009
after loosing power during the upgrade to the latest version, I now can not get the CCA (2.0) to work fully.  I will not load the voice data.  I have followed all instructions to reload manually.
chris unger Tue, 06/16/2009 - 12:15
Thanks for the reply.  I will follow the link.  I would reset the config back, but cant because the voice data doesn't load.  Thus, you cant do a factory reset.  I really am leaning on the fact that the VLAN.dat file is an issue.
aipcommunications Wed, 06/17/2009 - 13:44
Hi.  We had this exact same problem.  I created a Cisco TAC request, and worked with with an engineer on the problem.  In our case, it looks like something happened to the CUE module (as VMail and AA were no longer working), but CCA was showing the same behavior, where voice data wouldn't fully load, and hence the CCA was rendered useless (as most action bring up a "Voice data is still loading, please retry in a few minutes" message).  We logged into the CUE module via CLI, and it was stuck in a rebooting cycle, where it would boot up, then immediately shut down and reboot.
Is this similar to the symptoms you are experiencing?  If so, had you made any other recent changes to the system before the behavior occured? We started using the CCA 2.0, but had not upgraded to the new software package yet.
