VPN error
Answered Question
Jun 15th, 2009
I have set up a ipsec/ike vpn on my cisco pix ( 515E), ASDM version is 5.2(3), PIX version is 7.2(1) and enable IPSec over NAT-T
When the VPN connection authenticate the user via TACAC+, it works great...
however, now I try to set it up so that it will authenticate with the LDAP Authentication with Domain ( microsoft), and gives this error code....
"Secure VPN Connection terminated by Perr. Reason 433: (Reason Not Specified
by Peer)"
any idea?
Rachel
Correct Answer by andrew.prince@m... about 7 years 8 months ago
Rachel,
What is shown in the logs of your Domain Server?
Have you seen the below config example for LDAP auth:-
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008060f261.shtml
HTH>
Overall Rating: 5 (1 ratings)
rachelau_2005 Wed, 06/17/2009 - 01:57
Hi HTH
Thank you so much for the document, it is very useful.
I have set it up according to the info and now it works, thanks a lot for your help!!! you are awesome!
thanks
kind regards
Rachel
