Call forwards?
Jun 15th, 2009
Right now 555-555-4290 rings on two lines: 4297 and 4293, but it does *not* ring on 4295.
I need to get 4290 to also ring on 4295.
I'm trying to learn CME, so I'm not quite sure what I'm looking for; what controls this forwarding.
I do a search for "4290" and the only line I see is:
voice translation-rule 1
rule 5 /5555554290/ /8200/
Then do a search for "8200":
dial-peer voice 8200 voip
description SIP Dial-Peer to CUE for AA
destination-pattern 8200
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
voice-class source interface Loopback0
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
And:
dial-peer voice 2006 voip
description ** cue auto attendant2 number **
translation-profile outgoing PSTN_CallForwarding
b2bua
codec g711ulaw
no vad
Could anyone point me in the right direction here?
I can only assume there is some type of "pool" that 4290 forwards to, I'm just not sure where/how this is defined.
Overall Rating: 3 (1 ratings)
paolo bevilacqua Tue, 06/16/2009 - 00:07
  • Hall of Fame,
    Founding Member
Check the configuration for the two ephones where is ringing now. From there, you will understand how to configure the third.
Note, if that is shared lines, it has caveats, but that can be seen later.
scott.bridges Tue, 06/16/2009 - 05:12
Hello, Thanks for your reply.
I have actually studied those ephone config's very closely; that's how I was able to configure the receptionists' phone initially.
13 = reception
15 & 12 = two phones where the main number already rings.
I'm just not seeing how the ephone config affects where the main number rings?
ephone 13
device-security-mode none
video
mac-address XXXX
ephone-template 1
username "receptionist" password 12345
type 7965
button 1:17 2:15 3:12
ephone 15
video
mac-address XXXX
ephone-template 1
username "Muser" password 12345
type 7965
button 1:15 2:12 3:21
ephone 12
mac-address XXXX
ephone-template 1
username "Vuser"
type 7945
button 1:12 2:21
Am I missing something?
paolo bevilacqua Tue, 06/16/2009 - 05:17
  • Hall of Fame,
    Founding Member
Now look at ephone-dn 21, possibly has the number you're after.
So:
ephone 13
button 4:21
scott.bridges Tue, 07/07/2009 - 16:44
Update:
This post basically put me on the right track.
The ephone's that were ringing had a DN with extension "8800" bound to it. Once I was shown how to log into the Integrated Services engine, I saw that option "0" forwarded to this "8800" extension, then was able to reassign this DN to what I wanted.
Resolved.
