voice port not appear in running-config
arianto.wibowo
Hi all,
I have problem with my C3660.
I want to configure this router as voice gateway.
But unfortunately, my voice port doesn't appear when I type "sh run".
But it is detected when I issue command "sh ver" and "sh diag".
My voice modul using 4 PORT Voice PM for MARs Port adapter (2FXS and 2FXO).
Thanks for any help.
ari
6 Replies 6
paolo bevilacqua
Are there the DSP on the NM ? Check show diag.
I'm using this module
Slot 3:
High Density Voice Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
Top Assy. Part Number : 800-XXXXX-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : JABXXXXXXXX
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
0x10: 42 47 30 80 00 00 00 00 02 02 C1 8B 4A 41 42 30
0x20: 35 34 36 30 43 4E 42 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
T1 (1 Port) Multi-Flex Trunk WAN Daughter Card
Hardware revision 1.0 Board revision A0
Serial number 27XXXXXX Part number 800-03568-03
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 20 01 00 01 9F DA 68 50 0D F0 03 00 00 00 00
0x30: 50 00 00 00 01 11 08 00 FF FF FF FF FF FF FF FF
HDV firmware: Compiled Mon 26-Nov-01 16:24 by miriyala
HDV memory size 524280 heap free 202857
Seems like there are no DSP on it.
For sure no FXS/FXO ports.
Kindly find sh diag attachment
I have same 2 devices (Router 3660), one is work, but not for the other.
What IOS feature set are you using? Are they feature sets or versions different between the top routers?
Using c3660-ik8s-mz-122-6c-M1.bin for both
Seems like the problem is on NM voice module (2V).
What do you think ?
