Jun 15th, 2009
hi guys ,
it is regarding to the outdoor wireless lan consist of several mesh AP.I have two wlc 4402 , and right now ima trying to test out on the failover issue. It works fine actually but however,on one of the mesh AP i attached a ip camera to the PoE out using the UTP cable.Eventually ,the ip camera fails to failover.It just repeatly shows request time out until...what i do is that on the WLC ,I have to unchecked and checked the vlan transparent and then the ip camera(the ping) is up again.Strange isn't it ?
That Mesh AP is a MAP and belongs to native vlan 4 while the ip camera belongs to another vlan of 28.
Appreciate if anyone could solve this problem i had . Kindly ask me anything if you need any other info coz tis is my 1st time asking question in the forum.
Thanks in advance my fren.
My email is :[email protected]
chanqifeng Mon, 06/15/2009 - 23:13
sry there is a typo .. shld be "i have to checked(enable) and unchecked(disable) the vlan transparent and then the ip camera (the ping) is up again"
