WAAS Software 4.1.3 Question
Jun 16th, 2009
Hi all,
Ordering SW 4.1.3, Do I need to order license for WAAS Central Manager or it will be included in Enterprise lic?
If yes, so should I order enterprise lic for WAE(Central manager)?
dstolt Tue, 06/16/2009 - 05:14
  • Cisco Employee,
Starting with WAAS 4.1.1, the CM uses the Enterprise License and there is no longer a separate license for the CM function.
Hope that helps,
Dan
