LMS 3.1 on System Hardening
Jun 16th, 2009
Could be LMS 3.1 installed on a System Hardening? We are getting many issue after that we have installed the LMS 3.1 on System hardening. Is there any special procedure to install the LMS 3.1 on Solaris 10 System hardening?
Thanks for your responses
Joe Clarke Tue, 06/16/2009 - 08:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
LMS is not tested with a hardened Solaris OS. We have no documented procedures to do it.
Marvin Rhoads Tue, 06/16/2009 - 12:22
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
While not a strictly "supported" installation, it is possible to harden a Solaris host that has CiscoWorks LMS installed on it.
You need to pay careful attention to the ports required by CiscoWorks and make sure that your hardening has not blocked the ports or their associated applications from communicating. See http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1108769 for details.
Marvin Rhoads Tue, 06/16/2009 - 14:27
Addendum:
A team I worked with successfully adapted a hardened Solaris 9 installation using the United States National Security Agency (NSA) hardening guidelines posted here:
http://www.nsa.gov/ia/guidance/security_configuration_guides/operating_systems.shtml#sun_solaris
and, more specifically, here:
http://www.nsa.gov/ia/_files/os/sunsol_9/I331-007R-2004.pdf
