Upgrading dial plan
Jun 16th, 2009
Just looking for some advice.
I need to upgraded the dial plan on a CCM running version 4.2(3)sr1
I need to find out what version I am currently running on and then install the downloaded file.
Looking in the GBNP file I believe I am using version 28 however the file I downloaded does not display the version in the same format so I'm unsure how to interpret if its actually a newer version. The file name is dp-ffr.1-1-8.GB.exe
Any feedback appreciated.
