etherchannel
Jun 16th, 2009
Hi all, when setting up etherchannel on switch, do I have to set the port vlan memberships, and trunks on the individual ports and also the port channel afterwards ? or do I just do it on the port channel ?
Overall Rating: 4 (1 ratings)
mahmoodmkl Tue, 06/16/2009 - 03:51
  • Gold, 750 points or more
If u enable it on the port channel interface it will be effected on the physical interfaces.
Mahmood
carl_townshend Tue, 06/16/2009 - 04:34
what do you mean here?
I can just do all the config on the port channel rather than individual interface ?
mahmoodmkl Tue, 06/16/2009 - 04:44
yes u can do the config on portchaneel and it will reflect on the physical interfaces.
Mahmood
