AIP-SSM How to Verify Traffic is being passed for inspection?
Jun 16th, 2009
"show conf" command on my AIP SSM CLI. gigabitEthernet0/1 backplane interface of the SSM has not been assigned to virtual sensor vs0.but
Through this command show service-policy
traffic is recevied by IPS Module.why this,
Kindly guide me
abinjola Tue, 06/16/2009 - 04:07
  • Cisco Employee,
show service-policy will show you packets being sent to the module, however if you have NOT assigned the backplance interface to VS0 then no action would be taken on those packets
kiani Tue, 06/16/2009 - 04:11
Thanks,i got it.
Cinet-IPS1# show statistics virtual-sensor
Virtual Sensor Statistics
Statistics for Virtual Sensor vs0
Name of current Signature-Defintion instance = sig0
Name of current Event-Action-Rules instance = rules0
List of interfaces monitored by this virtual sensor = GigabitEthernet0/1 subinterface 0
General Statistics for this Virtual Sensor
Number of seconds since a reset of the statistics = 434653
SensorApp Memory Use Percentage = 33
Processing Load Percentage = 1
Total packets processed since reset = 1722
Total IP packets processed since reset = 1722
Total IPv4 packets processed since reset = 1722
Total IPv6 packets processed since reset = 0
Total IPv6 AH packets processed since reset = 0
Total IPv6 ESP packets processed since reset = 0
Total IPv6 Fragment packets processed since reset = 0
Total IPv6 Routing Header packets processed since reset = 0
Total IPv6 ICMP packets processed since reset = 0
Total packets that were not IP processed since reset = 0
Total TCP packets processed since reset = 1466
Total UDP packets processed since reset = 0
Total ICMP packets processed since reset = 256
Total packets that were not TCP, UDP, or ICMP processed since reset = 0
Total ARP packets processed since reset = 0
abinjola Tue, 06/16/2009 - 04:33
  • Cisco Employee,
use the following command
(config)# service analysis-engine
virtual-sensor vs0
(config-ana-vir)# physical-interface gigabitEthernet0/1
Now do show statistics virtual-sensor it should show gig0/1 assigned
