Incoming Translation (prepend 9)
Jun 16th, 2009
Hi. I have question regarding incoming translations. I can make and recieve calls fine.
I currently dial out using a 9 and use a SIP trunk. I want to prepend a 9 to calling numbers so I can use the missed call button etc. This would also mean that if I have a directory entry such as
directory entry 10 90208 111 111 name EXAMPLE
I should be able to see EXAMPLE on the phone when 0208 111 111 calls. I will also be able to use EXAMPLE from the directory on the phone.
I tried to create the translation (below) and added to the SIP incoming dial peer (1000), but this does not have seemed to work.
Can anyone assist?
voice  translation-profile PREPEND_NINE
translate  calling 777
voice  translation-rule 777
rule  1 // /9\1/
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
translation-profile incoming ADD_NINE
session protocol sipv2
session target sip-server
incoming called-number .%
dtmf-relay rtp-nte
ip qos dscp cs3 signaling
no vad
Skyler Spence Tue, 06/16/2009 - 07:04
  • Bronze, 100 points or more
Was this a typo?
Skyler Spence Tue, 06/16/2009 - 08:12
Ok, most likely what is happening here is that your incoming numbers are being sent with the E164 "+" prepended to the calling number.  After your current translation rule, the result then becomes 9+1xxxxxxxxxx which is an invalid E164 number and therefore the translation is rejected and the original calling number value is used.  Try changing your translation rule to
rule 1 /\+/ /9\1/
and tell me if that works.
dankennedy Tue, 06/16/2009 - 08:44
That didn't work. The SIP Provider seems to send to complete number (I am in the UK). I tested the translation after making the change you suggested and i get
DLXUC520#test voice translation-rule 777 012XXXXXXXX
012XXXXXXXX  Didn't match with any of rules
If I revert back to the orginal rule I was using I get the following.
Matched with rule 1
Original number: 012XXXXXXXX   Translated number: 9012XXXXXXXX
This would seem to work then, agreed?
But my missed calls do not have the prepended nine.
Any ideas?
Skyler Spence Tue, 06/16/2009 - 08:48
Check to make sure you are matching the correct inbound dial peer.  When configuring with CCA, if you have an incoming SIP trunk and you have configured inbound call routing (such as routing DID xxxxxxx to extension yyy) then you may have multiple inbound SIP dial-peers.  Check to see if this is the case.
You can check if the translation rule is being hit and if any errors are being produced with the
debug voice translation
command, be sure to use the "term mon" command to see the output.  Then try an incoming call and attach the output here (edit out your phone number before posting).
Steven Smith Tue, 06/16/2009 - 08:49
  • Gold, 750 points or more
If the rule is correct, the next possibility is that you aren't matching that dial peer on inbound calls.  I would make sure that this dial peer is being matched instead of another actually being matched, and the dial peer not being applied.
Marcos Hernandez Tue, 06/16/2009 - 08:52
  • Blue, 1500 points or more
CCA 2.0 offers an inbound dial plan test, under the Troubleshooting tab.
Marcos
dankennedy Tue, 06/16/2009 - 09:18
You were correct. I had a dial-peer with a translation for the main number to a hunt group. As this was more specific it was being used.
I just had to add add a calling number translation under that peer.
Thanks very much for your help.
