LDAP Integration
Answered Question
Jun 16th, 2009
I am setting up LDAP Authentication with a Microsoft Windows Server 2003 and needed to check 2 things:
1. I can only make the authentication operate successfully when using the domain administrator account if I try using other accounts even if they are in the same cn I get the error message Authentication Server nor responding: 'AAA Server has been removed.' Can I make authentication work with an other user account and what are the least privilidges I need to assign to the account?
2. Not critical but I like to use passphrases for Active Directory user accounts - the AAA server setup will not accept passwords with spaces when configuring ldap authentication is there any way round this?
Ass always thanks for your help
Correct Answer by srue about 7 years 11 months ago
i made this a few months back, maybe it will be of some help.
Overall Rating: 4.5 (2 ratings)
sjones1966 Tue, 06/16/2009 - 06:38
Should have included Cisco ASA 5520 (ASA 8.0(3) ASDM 6.1(1)
Correct Answer
srue Tue, 06/16/2009 - 06:53
  • Blue, 1500 points or more
sjones1966 Wed, 06/17/2009 - 06:08
Thank you very helpful - LDAP VPN authentication is now using the correct Login DN.
