Rv042 -Multiple Ip-adresses and remote desktop
Jun 16th, 2009
I have set upp two Rv042 routers, internet and a router-router vpn connection works perfectly.
I have multiple IP-adresses from my ISP at both ends. How do I move the VPN connection to an other ip at both locations, currently I am using the same as for the internet.
Also I have troubles getting the router to allow me to access our windows server from home. I'm using the remote access service in w2k3 server which worked with the old router. I use PPTP protocol. Which ports should be set up for this service? I have tried a bunch but have had no success. I would like this incoming connection to use an other of my ip-adresses. Which settings are needed in the router? Have addded port trigger and forward for the ports and made a passtrough trough the firewall to the server Ip-adress.
karlsson.andreas Tue, 06/16/2009 - 07:03
I had a glance at the guides but none seem to match my problem, will look closer late on.
My internet modem only features one ethernet connection therefor I can only use one of the wan ports.I have 5-6 Ip adresses. Is it normal for all to be redirected to the one uses by the gateway?
I would like not to use the VPN servic provided by the router to spare its memory and cpu as I have a server for this. I can take a second look at the cisco vpn client, if i use it do i need to make open ports in the firewall in the router or is it selfmanaged?
Te-Kai Liu Tue, 06/16/2009 - 15:01
If you have multiple public IP addresses, you can set up the 2nd WAN port as a DMZ Port (e.g. using DMZ Range if the IP addresses are in the same subnet of the ISP).
karlsson.andreas Tue, 06/16/2009 - 23:24
When i change to dmz i get som intresting alterantives. But do i connectet another "switched" cable from the modem or do i use it as the output of the dmz settings?
Te-Kai Liu Wed, 06/17/2009 - 00:34
For DMZ, you would want to connect the WAN2/DMZ Port to a switch, which connects to all the PCs that will be assigned the public IP addresses given by your ISP.
