logging asa debug to syslog?
Jun 16th, 2009
I have syslog set to log to level 7...but I am doing a "debug sqlnet 255" to resolve an inspection issue and the debug messages only show up when I am logged into the ASA, they dont get sent to the syslog server.
how can i resolve this?
Overall Rating: 5 (1 ratings)
abridge-cco Wed, 06/17/2009 - 08:58
make sure your server configuration is correct, your asa has the correct server IP address, and that your server itself doesn't have anything blocking the UDP port for syslog.
John Blakley Wed, 06/17/2009 - 09:04
  • Purple, 4500 points or more
You need to trap your messages. If you can post your logging config, I can help you out further, but generally you'd want:
logging enable
logging trap 7
logging facility 23
logging host inside
The facility 23 line is a syslog server running on Linux. There are different facilities, but 23 generally works for all that I've found.
HTH,
John
slug420 Wed, 06/17/2009 - 12:41
was just pasting my logging config here and I realized the problem. You must use:
logg debug-trace
in order to send debug messages to syslog, otherwise they only show up at console which is what I was experiencing.
