Warning message
SUP720-3BXL BGP Routing / SLB ISSUE
Jun 16th, 2009
I have put in service a new SUP720-3BXL on a 6509 to replace BGP routing on 7204 VXR with NPE-G1.
So, I have severals SLB working on the 6509 with SUP1A.
I have replaced the sup1A with SUP720 3BXL.
I have configured a BGP Sessions with one of our provider and bring it up.
Now, I have some trouble with SLB which are switching to failed when I begin to advertised the route concerned by this SLB.
Here are the error logs :
Jun 16 16:15:14: %SLB-6-REAL: Real A.B.C.D (SERVERFARM) has changed state to FAILED
Jun 16 16:15:50: %SLB-6-REAL: Real A.B.C.E (SERVERFARM) has changed state to FAILED
Jun 16 16:16:27: %SLB-6-REAL: Real A.B.C.F (SERVERFARM) has changed state to FAILED
Here the part of the conf concerned by that :
ip slb serverfarm SERVERFARM
nat server
predictor leastconns
real A.B.C.D
inservice
real A.B.C.E
inservice
real A.B.C.F
inservice
real A.B.C.G
no inservice
ip slb vserver EU
virtual A.B.C.H tcp www
sticky 600
inservice
ip slb vserver FR
virtual A.B.C.I tcp www
sticky 600
inservice
ip slb vserver COM
virtual A.B.C.J tcp www
sticky 600
inservice
ip route A.B.C.0 255.255.255.0 X.X.X.X
And a show ver :
System returned to ROM by reload at 07:25:46 UTC Mon May 4 2009 (SP by reload)
System restarted at 11:01:58 CEST Mon May 11 2009
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-18.sxf3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 3.0) with 983008K/65536K bytes of memory.
Processor board ID SAL0804TEAF
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
7 Virtual Ethernet/IEEE 802.3 interfaces
144 FastEthernet/IEEE 802.3 interfaces
10 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Do I have misconfigured the SLB ?
Thank for your answer,
Giuseppe Larosa Wed, 06/17/2009 - 08:55
  • Hall of Fame,
    Founding Member
Hello Yousri,
your configuration looks like fine.
You have changed the supervisor HW and the IOS release.
I've checked release notes and software based IP SLB is supported with your supervisor and your IOS image.
However, I would try to install a newer image you may be hitting a SW bug. What image to choice depends from the modules that are in the chassis.
Hope to help
Giuseppe
