UCCX TAPS exception error
Jun 16th, 2009
CM - 6.1.3.1000-16
UCCX - 5.0.(2)SR02_Build045 (HA enabled)
TAPS App trigger - 4888
Installed TAPS on production UCCX server and get an error when I reactive debug the TAPS.aef script (see attachments). In the MIVR log look for line 87392. I included a couple of screenshots, including the java expression the Set Step is calling.
Is the object it is saying it can't find on Line 1 Column 59 embedded in the TAPS.jar loaded in the Document/Classpath area?
Also, could the local it is looking for be the country specific language configuration? This was built as EN only, not EN_US.
Thank you, Dave
Tommer Catlin Tue, 06/16/2009 - 20:22
  • Green, 3000 points or more
Just so it's documented here. Restarting the TAPS service on the CUCM Publisher kicked something and now it works. (or at least answers correctly now) Now, see if a phone registers!
davidkcampbell Tue, 06/16/2009 - 20:26
I was able to get this working. Had to reset the TAPS service in CCM. TAPS was active, but a restart fixed the issue.
