Changing the ODR distance on the spokes
Jun 16th, 2009
I'm looking for a way to change the ODR distance on the spokes so they can prefer one hub over the other w/o balancing. The solution has already been proposed by CSCdr35460, but configuration details are unavailable.
Laurent Aubert Tue, 06/16/2009 - 19:14
This featurette has never be implemented so you it's still not supported.
If you want it, you can work with your local Cisco account team which will help you to make a feature request.
