How to configure remote access VPN for mobile user in UC?
Jun 16th, 2009
Does anyone ever try this before?
Thank you for your assistance guys.
Marcos Hernandez Tue, 06/16/2009 - 08:30
This is extremely simple. Open CCA 2.0 and go under "Configure >> Security >> VPN Server" The configuration options are self explanatory. You will need a public IP (preferably static) on the WAN interface of your UC500.
Then, follow this document to create a profile that can be used by the Cisco VPN Client to access the main office:
https://www.myciscocommunity.com/docs/DOC-3250
Marcos
Steven DiStefano Tue, 06/16/2009 - 08:30
Or if this is a 'mobile' with CIPC (really mobile) then you can just use the Cisco VPN CLient with a CIPC.
The document I referenced is a Fixed Teleworker....
