06-16-2009 08:31 AM - edited 03-10-2019 04:32 PM
Good Afternoon,
We are trying to log CLI commands to Cisco ACS version 3.1 from Nortel Passport 8600's. The version of code running on passports does not support tacacs+.
The Passports authenticate okay but do not log any command information. I "think" the problem may be that the Radius Nortel VSA for cli-commands-attribute, 195, is not being collected by ACS.
Does anyone know how I would go about getting this VSA added in to the existing Radius(Nortel) list?
Many thanks,
Flett.
Solved! Go to Solution.
06-16-2009 09:19 AM
Flett,
You need to add Nortel attribute 193-195 to enable command accounting.
Unfortunately you cannot upload it on 3.x code, so you need to upgrade acs to 4.x code.
~JG
Do rate helpful posts
06-16-2009 09:19 AM
Flett,
~JG
06-16-2009 12:42 PM
Thanks very much for your help JG.
Do you know if it is an easy thing to do on ACS 4.x?
Flett.
06-17-2009 01:01 AM
06-17-2009 01:16 AM
Thanks once again JG
