06-16-2009 08:37 AM - edited 03-15-2019 06:33 PM
Initial Phase
PSTN (xx1000-xx2999 DID)->E1 R2-> PBX-> extensions (1000-2999)
Migration Phase
PSTN (xx1000-xx2999 DID)->E1 R2 -> C3845->E1 R2-> PBX -> extensions (1000-2000)
PSTN (xx1000-xx2999 DID)->E1 R2 ->C3845->GigabitEthernet->CUCM 7.0->extensions (2000-2999)
I want to migrate extensions 2000 to 2999 from PBX to IP Telephony.The PBX knows just E1 CAS R2 signalling.I put the router C3845 between PSTN and PBX but i know that CUCM 7.0 not support E1 CAS R2 signalling and is not possible to control E1 R2 interfaces on router C3845.
How i can make this migration?
Any suggestions? Any configuration example?
Thanks.
Solved! Go to Solution.
06-16-2009 09:29 AM
Use H.323 as protocol between CUCM and GW.
That way you can use E1 R2 or whatever else.
06-16-2009 09:29 AM
06-17-2009 09:50 AM
This configuration is good?
CUCM 7.0 - 172.16.0.10
C3845 - 172.16.0.1
CUCM 7.0 configuration:
-configure H323 gateway (device name : 172.16.0.1)
-configure route pattern to PSTN (route pattern: 9.@, gateway: 172.16.0.1)
C3845 configuration:
isdn incoming-voice voice
#e1 r2 to PSTN
controller e1 0/0/0
ds0-group 0 timeslots 1 31 type r2 digital
#e1 r2 to PBX
controller e1 0/0/1
#dial 2000-2999
dial-peer voice 2000 voip
destination-pattern 2...
session target ipv4:172.16.0.10
codec g711ulaw
dtmf-relay h245-alphanumeric
#dial PSTN
dial-peer voice 1 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
#dial 1000-1999
dial-peer voice 2 pots
destination-pattern 1...
port 0/0/1:15
06-17-2009 10:08 AM
usually there is more stuff configured for R2, you should find an example for your country.
06-17-2009 10:18 AM
but except r2 configuration, what is your opinion for the rest of configuration?
06-17-2009 10:23 AM
Seems fine, on the DP for the PBX you may want to have "forward-digits all" else it doesn't get all the digits.
Also, have network-clock-select from PSTN, use clock internal to the PBX.
In any case, I recommend you hire a professional for the job, because customer get nervous very quickly with PBXs and a beginner doesn't have the time to do trial and error.
06-17-2009 10:42 AM
06-17-2009 10:45 AM
I've answered you above.
