Q931 Set up Messages
Jun 16th, 2009
Hey All,
Does anybody know where all this information on the CONNECT and ALERTING stages of a call set up is coming from and what its for:
*Jun 16 15:59:38.989: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0011
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18392
Preferred, Channel 18
Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x2183, '703939030'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '4999'
Plan:ISDN, Type:Subscriber(local)
*Jun 16 15:59:39.109: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8011
Channel ID i = 0xA98392
Exclusive, Channel 18
*Jun 16 15:59:39.317: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8011
Progress Ind i = 0x8088 - In-band info or appropriate now available
User-User i = 0x05, '#', 0x8006000891, 'J', 0x00020201, ' ', 0x110000C71D, 'g', 0x91, 'x', 0xF11D9F17C3020A, '.b', 0x0B0AA001000F01, '@', 0xB50000120880A4000400010100
*Jun 16 15:59:39.361: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0x0011
Cause i = 0x82AB7E - Access information discarded
Call State i = 0x07
Display i = '888 TJ[NSTEN EJ AKTIV'
*Jun 16 15:59:39.365: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8011
Display i = '4428780'
User-User i = 0x05, '"', 0xC006000891, 'J', 0x0002000A9013, ' ', 0xE10B020000C71D, 'g', 0x91, 'x', 0xF11D9F17C3020A, '.b', 0x0B0900110000C71D, 'g', 0x91, 'x', 0xF11D9F17C3020A, '.b', 0x0B0AA001000F01, '@', 0xB50000120880A4000400010100
*Jun 16 15:59:39.409: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0x0011
Cause i = 0x82E328 - Information element not implemented
Call State i = 0x08
*Jun 16 15:59:39.413: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0x0011
Call State i = 0x08
*Jun 16 15:59:39.417: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00117
As you can see we get a message back from the Swedish Telco telling us that its all discarded.
This is MGCP E1 trunk to a Swedish carrier
Thanks guys!
paolo bevilacqua Tue, 06/16/2009 - 09:31
  • Hall of Fame,
    Founding Member
Yes the switch complains about the strange stuff but the calls is completed.
If you were to use H.323 you could control which IE are sent to the switch.
But, it seems it makes no difference.
craigneeld Tue, 06/16/2009 - 12:19
Thanks for the message but im afraid H323 is not an option. Im concerned about these IE elements, we have upto 40 E1 all configured exactly the same but these paticular links are the only one sending this info. They've both also crashed twice in the last 24 hours which I why I want to get to the bottom of why and by what they are being sent..
