Load Balancer
Jun 16th, 2009
We have ASA 5505 installed for our office and one Internet 2MBPS lease line for Internel and have 16 public IP's. One of the Public IP is assigned to ASA outside Interface and other are using by NAT. We have 10 branches connected via STS VPN Tunnel. Now we are going to have the second lease link for backup purpose and want to use both lines simultaneously. Is it possible by ASA 5505 or do i need to buy an extra device for that. Pls advice.
Collin Clark Tue, 06/16/2009 - 13:03
Does you 2mb leased line go directly into your ASA or does it go into a router first?
ray_stone Tue, 06/16/2009 - 13:24
If I use a router then is it possible, if it is then what would be the way and how can i use ASA FW for filtering the traffic as its already filtering by ASA.
plumbis Thu, 06/25/2009 - 20:27
This is not possible on an ASA. It only support multiple next-hop addresses out the same physical interface (e.g., two internet routers connected to the same switch as the ASA). You can only use the second internet link on the ASA as a backup.
