Bulk Admin @ CUCM61.3
Jun 16th, 2009
We want to update Voice Mail profile on DNs.
Not all DNs within the same device pool have voice mail.
The "Line update" in bulk admin. doesnt give you an option to upload file into the system.
Is there a way to upload the list of DNs to be modified where Vmail profile can be changed?
What would be the best way/steps to update voice mail profile of the DNs?
Fureya
Jaime Valencia Tue, 06/16/2009 - 16:58
  • Cisco Employee,
  • Hall of Fame,
    2011
You can use the update lines and do batches if the numbers are contiguous using wildcards in the search, otherwise it would be to export the phones, delete the phones and then reimport them with the right VM profile.
java
if this helps, please rate
