851W wireless routing issue
I've been running a small office with an 851W wireless router for over a year without issue. However, recently I have been having intermittent (every couple days) issues with the wireless. Specifically, connections via wireless can no longer route out or see other machines on the LAN. Wired connections continue to work fine. Also, you can still get a dhcp address via wireless, but as I mentioned, there seems to be a problem resolving internal and external addresses. I've scanned for other networks causing interference, but that doesn't seem likely as the only other networks in range are on different channels. Wondering if this might be a hardware problem with the router/radio. Any thoughts would be greatly appreciated. Thanks in advance.
vmoopeung Mon, 06/22/2009 - 05:00
You may try setting the channel to 2412 or "Current Frequency: 2412 Mhz Channel 1".
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
