EOD ?
Jun 16th, 2009
End-of-Life Milestones and Dates for the Cisco Catalyst 3560 IOS Advanced IP Services Feature Set
I can't seem to find what the EOD life is for 3560
I have WS-C3560-24TS-S 12.2(37)SE1
and WS-C3560-24TS-E c3560-advipservicesk9-mz.122-25.SEB3
iyde Tue, 06/16/2009 - 11:43
  • Silver, 250 points or more
What has happened is that Cisco has put the IPv6, which was the main "extra" in Advanced IP Services code, into the IP Services code, starting from 12.2(46)SE or 12.2(50)SE - I don't off the top of my head remember which.
This means that going forward you will have only IP Base and IP Services to choose between. As stated, this will be when you upgrade to past 12.2(50)SE.
HTH.
jfeo Tue, 06/16/2009 - 11:45
So the advance ip services I have is still Active
And there is no notice on EOD of the 3560
Thanks for your help
iyde Tue, 06/16/2009 - 13:18
Glad to have helped!
As for EoL/EoS for 3560 I do not have the specifics, but it will vary depending on the model, and most 3560 models to the best of my knowledge are still current.
