Compress IN NVRAM
Jun 16th, 2009
I have a configuration file of 70KB size but on my router I only 55KB nvram.
is there a way to compress the configuration.
hindhabaoui Tue, 06/16/2009 - 14:10
thanks for your reply
I have under question
can I use my carte flash instead of my NVRAM because I have a large file.
if yes tell me how.
Richard Burts Wed, 06/17/2009 - 09:48
I am not sure if it is model dependent or IOS version dependent, but I tested using the compact flash card to store the startup config and it worked well. I was testing on an 1841 running 21.4T.
tamerahmedov Tue, 06/16/2009 - 16:56
1- service compress-config,
2- copy running-config startup-config command
hindhabaoui Wed, 06/17/2009 - 12:43
I have done this but the following message appear:
Uncompressed configuration from 52150 bytes to 201331 bytes
