NCE - AIM-TPO-1
Jun 16th, 2009
This might be a really dumb question but here goes..... I recently have been testing the AIM-TPO-1 card to improve WAN perfomance to a remote site. I can see all kinds of stats regarding the TCP optimization and SCTP encapsulation but I don't see a command and can't figure out how to see what compression this card is doing. It is supposed to be doing layer 4 multicast and redundant header compression. Does anyone know the command(s) to display compression stats or can you point me a manual.
s.jankowski Mon, 06/22/2009 - 11:37
  • Bronze, 100 points or more
Use the show pas caim stats aim-slot command to display statistics describing the operation of the data compression AIM.
Use the show compress command to display the compression ratio and other data compression statistics for a data compression AIM or for software compression.
This command displays the number of the optimized connections and compression ratios
- sh tpo id statistics
