configuring rapid spanning tree
Answered Question
Jun 16th, 2009
folks
i have 2 * 3560es set up for resilience with 2 uplink ports but spanning tree takes 50 secs to failover so i want to enable rapid spanning tree
can anyone let me know the relevant commands or post a link for a config guide
i'm running c3560e-universalk9-mz.122-35.SE5
thanks to anyone taking the time to reply
Correct Answer by Jerry Ye about 7 years 11 months ago
Hi Michael,
To enable Rapid STP, all you have to do is use the spanning-tree mode rapid-pvst in global configuration mode.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_35_se/configuration/guide/swstp.html#wp1156866
Make sure you put this command on all your switches, otherwise the switch without this command will use 802.1D.
HTH,
jerry
Correct Answer by Jon Marshall about 7 years 11 months ago
Michael
Have a look at this document, it is for the 6500 but it is relevant to the 3560 -
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807b0670.shtml
come back if you have further questions.
Jon
Overall Rating: 5 (3 ratings)
mulhollandm Tue, 06/16/2009 - 15:09
jon
once again, thanks for your input
greatly appreciated
Correct Answer
Jerry Ye Tue, 06/16/2009 - 15:00
  • Cisco Employee,
Hi Michael,
HTH,
jerry
