When I try to connect the Detector module " Login incorrect"
Jun 16th, 2009
HI..
I have a question about Detector log.
We have purchaed the detector module with basic license at theae day.
I would like to upgrade the detector to 3G full license, So I tried to upgade XG os to our detector module.
I upgraded from ftp, and I confirmed that the module upgrade has completed, and reset" and then I reload the module.
after that, the module has come up with AP image(I checked this in the show module), so I connect to module like below"
"session slot # proc 1", but I can't find login propmpt, the error message was comed up with like below:
login incorrect
login incorrect
login incorrect
and the module reset my telent session or zombie(session was not closed) at some time.
What's the main reason like above symptom?
Should I replace the module?
I would appreciate if you give me a some advice
Thank you.
