SVI Broadcast ARP
Mhon Baul
Hi All,
I've tried to run a wireshark and i noticed that there is one host that sending broadcast arp. When i find which device it is, i found out that its the mac-address of the SVI interface of Core_Switch. Is this normal? Any suggestion is much appreciated.
Many Thanks,
Reymon
5 Replies 5
Laurent Aubert
Hi Reymon,
It's expected the switch sends ARP request if it needs to route traffic to host locally connected and their MAC-address are still unknown.
Laurent.
Hi Laurent,
Thanks for your fast response. I attached here the picture that i've sniff. I'm still confused.
Many Thanks,
reymon
Are all those IP addresses reachable ?
You could also sniff the IP packets the switch is receiving and see who wants to reach those addresses.
Laurent.
Yes,all of these IP's are reachables. How can i sniff the packets, is there something i need to config on the wireshark. thanks in advance!
regards,
reymon
You could connect your PC running wireshark on a dedicated port and use the span feature to have a copy of each IP packets received from any L3 interfaces except the one where there are the ARP request
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/span.html#wp1089465
Laurent.
