06-16-2009 06:18 PM - edited 03-06-2019 06:17 AM
We currently have a Cisco 2821 which does not keep it's changed configuration.
For example, after adding the MOTD, saving the config (#write memory and #copy run start) and reloading the router the changes are losted. Has anyone ever run into this problem before and what was the fix? Attached is the show tech. Any assistance would be greatly appreciated.
Solved! Go to Solution.
06-16-2009 07:59 PM
Looking at your boot statements the router is loading its config from a ttfp server and not the one in NVRAM. Either do a copy run tftp or reconfigure the router to boot from the config in NVRAM.
06-16-2009 06:48 PM
I would start sticking another flash card into the router
06-16-2009 07:59 PM
06-16-2009 08:46 PM
Thanks pompeychimes. That resolved my problem. Can you please elaborate on the router boot process?
06-16-2009 09:47 PM
Power on
POST
Bootstrap program loaded from ROM
Bootstrap program loads the IOS from Flash*
IOS loads the config file from NVRAM*
*IOS and config file locations can be manipulated with "boot" statements and changes to the config reg
