site to site vpn
Jun 16th, 2009
Dear All,
I am configuring site to site VPN, I have one 2811 and one 1811 cisco routers,
Please tell me by using this configuration do i need to dial ??? or it will connect automatically,,,
from the router it pings its live ip but dont ping inside ethernet interface...
do i need to add a static route??
Please check my configuration
sh run
Building configuration...
Current configuration : 5470 bytes
version 12.4
hostname MTL-2811
boot-start-marker
boot-end-marker
enable secret 5 $1$xxxxxxxxxxxxxxxxxxxxxx1k0
no aaa new-model
resource policy
memory-size iomem 10
ip cef
--More-- !
ip domain name 123.com.pk
ip name-server 10.16.6.11
ip name-server 10.16.7.12
voice-card 0
no dspfarm
username Junaid privilege 15 secret 5 $1xxxxxxxxxxxxxxxxxxxxxxx/
crypto isakmp policy 9
hash md5
authentication pre-share
crypto isakmp key Millat7400 address 55.55.55.10 (Other side live ip)
crypto ipsec security-association lifetime seconds 86400
--More-- !
crypto ipsec transform-set Millat6400 esp-3des esp-md5-hmac
crypto map Millat5400 10 ipsec-isakmp
set peer 55.55.55.10 (other side live ip)
set transform-set Millat6400
match address 175
interface FastEthernet0/0
ip address 192.168.74.1 255.255.255.0
ip access-group Internet in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 55.55.555.21 255.255.255.248
ip nat outside
--More-- ip virtual-reassembly
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 55.55.555.17
ip route 192.168.1.0 255.255.255.0 192.168.74.2
ip route 192.168.2.0 255.255.255.0 192.168.74.2
ip route 192.168.3.0 255.255.255.0 192.168.74.2
ip route 192.168.4.0 255.255.255.0 192.168.74.2
ip route 192.168.5.0 255.255.255.0 192.168.74.2
ip route 192.168.6.0 255.255.255.0 192.168.74.2
ip route 192.168.7.0 255.255.255.0 192.168.74.2
ip route 192.168.8.0 255.255.255.0 192.168.74.2
ip route 192.168.9.0 255.255.255.0 192.168.74.2
ip route 192.168.10.0 255.255.255.0 192.168.74.2
ip route 192.168.11.0 255.255.255.0 192.168.74.2
ip http server
no ip http secure-server
ip nat inside source static tcp 192.168.1.4 22 interface FastEthernet0/1 22
ip nat inside source static tcp 192.168.74.1 23 interface FastEthernet0/1 23
ip nat inside source static tcp 192.168.1.16 80 interface FastEthernet0/1 80
--More-- ip nat inside source static tcp 192.168.1.16 25 interface FastEthernet0/1 25
ip nat inside source static tcp 192.168.1.16 110 interface FastEthernet0/1 110
ip nat inside source list 160 interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.1.15 3389 interface FastEthernet0/1 3389
ip access-list extended Internet
permit ip host 192.168.2.2 any
permit tcp any any eq smtp
permit tcp any any eq pop3
permit ip 192.168.20.0 0.0.0.255 any
permit ip 192.168.1.0 0.0.0.255 any
permit ip 192.168.74.0 0.0.0.255 any
permit ip 192.168.11.0 0.0.0.255 any
access-list 160 permit ip any any
access-list 160 permit tcp any any
access-list 175 permit ip 192.168.74.0 0.0.0.255 55.55.55.10 0.0.0.3
snmp-server community public RO
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps cpu threshold
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
control-plane
--More-- !
line con 0
password xxxxxx
login
line aux 0
line vty 0 4
password xxxxxx
login
scheduler allocate 20000 1000
end
MTL-2811#exit
Same configuration on the other side,
Please Advise
Junaid
junshah22 Wed, 06/17/2009 - 07:56
In this example, Author Suggested to make an ACL 175 for permitting the required traffic which will use VPN connection,,,
In my scenario,, My Internet Dont runs without NAT Overloading,, so I made an ACL 160 and permitted ip any any and tcp any any
Should I modify the existing acl 160 and apply the same on the
match address 175
and to replace 175 with 160..
in this case,,,, the other side router is able to get access into my network as well its internet service runs,,, but Internet service on first router stops,,
Please advise
auraza Wed, 06/17/2009 - 08:07
  • Cisco Employee,
What is the inside network on the other side? The crypto acl you are using references the outside IP/network of the remote host, and not the inside network.
