FAX Server Installation
Jun 16th, 2009
I need to install Fax server at one of our client. They are having PRI DID numbers. Is it possible to configure the extension is same for Voice and FAX ?
And Please give me a sample configuration for the this scenario if it is possible ..
thejas.ramadas Wed, 06/17/2009 - 06:29
Yes We have CUE and one cisco MCS server for Right Fax also.
Can you give me a configuration example?
Nicholas Matthews Wed, 06/17/2009 - 06:44
This is not a CUE feature, but rather a script you put on your incoming dial peer. If it detects fax tones it sends it to a configured fax number, if it does not, it sends it to an auto attendant or some other number.
