Serial Habdoff to Ehternet Handoff
Answered Question
Jun 16th, 2009
Want to convert serial hand-off to Ethernet hand-off using 1841 Router in order to connect to the ASA.
i have a /30 for the internet to the Router and a /29 between router and ASA.
There are IPsec tunnels too
how to route and whats the configuration for ASA and route
Correct Answer by Giuseppe Larosa about 7 years 9 months ago
Hello Logesh,
R1:
ip routing
int ser0/0
ip addr x.x.x.2 255.255.255.252
int fas0/0
ip addr y.y.y.2 255.255.255.248
ip route 0.0.0.0 0.0.0.0 x.x.x.1
ip route internal-net mask y.y.y.1
ASA
it is similar with
ip route 0.0.0.0 0.0.0.0 y.y.y.2
you need more for a working configuration.
the following link provides configuration examples for ASA and pix
http://www.cisco.com/en/US/products/ps6120/prod_configuration_examples_list.html
Hope to help
Giuseppe
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 06/16/2009 - 23:17
  • Hall of Fame,
    Founding Member
Hello Logesh,
R1:
ip routing
int ser0/0
int fas0/0
ASA
it is similar with
Hope to help
Giuseppe
Hope to help
Giuseppe
